Old 03-11-2019, 07:43 AM
RockBit's Avatar
RockBit RockBit is offline
Cobra Make, Engine: ERA #812 427/482 FE
Originally Posted by Alfa02 View Post
Good thought ! I run a 275-60-15, where most other's here run the 295-50-15 rear's. Would that make my angle a touch different, maybe? Mine was zeroed out, on the cowl, then measured on the windscreen, so maybe not? I'm confused, which doesn't take to much, now-a-day's ???
If you zeroed out on the cowl then you are measuring the angle with respect to the car. Ride height will not affect the angle.
Ride height only affects the angle if you measure with respect to horizontal or vertical, such as with a bubble level.
Chris
