Old 05-13-2019, 08:32 AM
rbgray1's Avatar
rbgray1 rbgray1 is offline
Originally Posted by Pasta Power View Post
I to have a Classic Roadsters I and a 351W with March pullies, I found a shop in New York, or new Jersey he custom assembles the Ford FE style expansion tanks to your specifications, I was very happy with his work, I can look up his info and share it if your interested.
Pasta Power, thank you for the response. The problem I'm having with the March Pulley system is that there is a diagonal brace for the alternator tension that runs fairly near the thermostat housing on a 351W Ford Engine. I was planning on changing the tstat housing to an upright or horizontal style to work around the March tension arm for the alternator.
Can you send a closer picture of this area on your set-up? I also would appreciate if you could provide the info for the location that built your FE style expansion tank.
