Old 01-06-2020, 07:39 AM
MKS427's Avatar
MKS427 MKS427 is offline
Cobra Make, Engine: FFR MkIV 427
You simply can't put any of these engines together reliably without using sealant on both sides of the intake gaskets. Every engine I build, whether it's a Windsor, Cleveland, FE, etc., gets the gaskets glued to the heads, and sealant between the gasket and the intake.
Which glue/sealant are you recommending at heads, intake, and china wall?
Thanks,
Mark
