Old 12-30-2020, 06:41 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Scenario 1, 445 ci Ford FE:
Camshaft 1: 286/294, 231/239 @ .050", 114 LSA, 108 ICL, .630"
Camshaft 2: 286/290, 231/235 @ .050", 113 LSA, 108 ICL, .630"
(If you'll notice, the overlap is exactly the same on these two cams)
Scenario 2, 354 ci Ford Cleveland
Camshaft 1: 289/297, 259/267 @ .050", 108 LSA, 106 ICL, .700"/.660"
Camshaft 2: 287/315, 257/277 @ .050", 112 LSA, 108 ICL, .700"/.700"
(Overlap the same on these two cams as well)
I don't understand. Looking at the FE cams specs, I would have thought the second cam would need a LSA of 112 to make the overlap identical.
regarding the 351 cams, I would have thought the 2nd cam would need either a LSA of 116 or 112 (depending if took gross lift duration or at .050) to have the same overlap.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
