Old 06-19-2022, 01:56 PM
DanEC's Avatar
DanEC DanEC is offline
You could actually test out the modification with two feet of twelve gauge wire with alligator clips on each end. Clip one gator end on the top post of the circuit breaker over by the starter solenoid and the other end on the passenger side clip of the #1 glass fuse. Then just drape the wire behind the engine so it's not in the way of anything (like maybe the throttle linkage). Then drive your car around for a weekend and see if you like the new behavior of the amp gauge.
Got it - top screw post on the relay and over to pass side of #1 fuse. May be a few weeks before I can try it out but I’ll try it and see what happens. What should I expect to see - just smaller flickers in the gage?
ERA 782 Running
