Old 01-04-2023, 08:29 AM
patrickt patrickt is offline
Originally Posted by davids2toys View Post
That sounds a lot easier, can you post a link for the one you have?
But it might not be.... For that toggle light to come on it must have both 12v+ and a ground connection there at the switch. The ERA dash toggle switch for the fans is passing a ground connection only to the fan relay. There is no positive feed there at that switch. Changing it out to a "lit" toggle may be more complicated than you think, especially if that "lit" switch is designed to control the positive feed and the little light is an LED.
