Thread: hard clutch
Old 06-12-2023, 06:22 AM
genolan genolan is offline
Cobra Make, Engine: Backdraft 1048
Originally Posted by HTM101 View Post
I use a hydraulic throw-out bearing and for years it was connected with a 3/4" master cylinder. It was a stiff combination. Last year I replaced the master cylinder with a 5/8" master. What a difference.
did you have any issues with clutch disengagement? I have the same problem and couldn't find a slave clutch that fits with a 7/8bore. I did notice the pedal has a hole 1 inch higher that would help mechanical advantage but that requires the master to be moved up to keep alignment.
Gary
Backdraft 1048
