Old 07-06-2002, 09:21 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Do not use synthetic oil!! Did you break in the cam for 20-25 minutes at 2,500 rpm? If not, do this first. If your block was honed with deck plates, the cam break-in procedure should seat the rings by then.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
