Old 02-16-2003, 11:34 AM
Mark IV Mark IV is offline
Senile Club Cobra Member
Default SFCJ...
....look at www.gt40s.com and search for threads involving FI. There are a couple of outfits that do an 8 stack system that gives the "Weber Look" but allows the tuneability and slick running of a EFI system.
There are several pictures there of systems on both 289/302 units and 351 systems.
I really like the 302 stroker idea myself as you can have the look of the 289 (302 is externally the same) and yet get some good power and torque without needing to build a hand grenade. Good set of aluminum heads and you have more power available than the team cars ran in the 60's with all day reliability.
There is even a shifter set up for the 5 speed that looks like the 60's FoMoCo shifter with the reverse lock-out ans all.
As this is a "hybred" car no need to do it any way except the way you want to.
Make sure you have an "FIA suitcase" to carry in the trunk! A nice portable bar setup would go nicely inside it. Filled with Raki and moonshine. Good use of the trunk dimples!
Rick
rick@autoventureusa.net
