Old 05-11-2003, 03:30 AM
ted ted is offline
Default Sideoiler Conversion
Although I've converted standard top oiler blocks to side oiler design by coming in through the main caps and feeding the oil at the bottom of the bearing, the block ideally already needs to have the casting in place to accommodate the side oiler drilling.
During the eighties and early nineties, I came across a number of industrial center or top oiler 427's that were cast as sideoilers but drilled only as top oilers. On those blocks, I never felt that the side oiler design was worth the additional expense or trouble to convert them to a sideoiler design if the appropriate oil gallery mods were performed on the top oilers.
Personally it's not worth the trouble on a used block even if the casting provisons are there for the sideoiler.
Ted Eaton.
Fe's are fast but "Y-Blocks" are fun when they run in the 9.60's at 135 mph.
