Thread: Crank bearing
Old 07-29-2003, 05:28 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
YES! It is bronze and the entier drive train usually vibrates or worst if it is not installed.
If you have a big bone toploader, you will need to find the truck adaptor pilot bearing. OR, you can call David Kee and ask for a special input shaft that has a longer snoot.
If you have an 1 1/16 input shaft, you just need to find a pilot bearing.
Tap it in with a plastic hammer, dial it to make sure it is round in the butt of the crank and then dab a little grease in it.
Hope this helps.
