Old 11-22-2003, 06:13 AM
Steve Vague Steve Vague is offline
Cobra Make, Engine: Aurora, 289 Slab Side Replica
The engine ran, and I am positive of TDC (compression, #1). I am not clear about rotating oil pump. Would this not change the timing ..180 degrees? If so, is this a problem, or would this just reset timing sequence?
I am planning on installing a new distributor,(MSD) but with all the changes I am making I was trying to reduce the "unknowns" . IE when engine refuses to fire up after all my changes, I wanted to reduce the potential "ROOT CAUSES".
Thanks for your ideas!
