Old 11-28-2003, 02:40 PM
Cal Metal Cal Metal is offline
Original Shelby Owner
You are going to have a difficult time finding a 31 spline output. These are obtainable new and, if you find a used one, you need to check the splines for twist.
If I were you, concentrate on the short tail small in/small out (input and output). If you really want a 31 spline, just buy a new one from David Kee. They are not that expensive. If you rebuild, you will probably be throwing away a lot of the existing components, anyway. Concentrate on a non cracked main case and tail.
