-   429/460 Engine Talk (http://www.clubcobra.com/forums/429-460-engine-talk/)
-   -   may want to get rid of stack injection for a carb (http://www.clubcobra.com/forums/429-460-engine-talk/112441-may-want-get-rid-stack-injection-carb.html)
fordracing65 09-08-2011 08:47 PM
thats the good thing about it if its not an original cobra who cares
Slither 09-08-2011 10:27 PM
I have experienced the following after going to fuel injection: The efficiency of fuel injection made my cars exhaust a bit quieter, the roughness or lumpiness at idle was far reduced, I'm sure the fuel mileage had to improve, the car is much more drivable and responsive and it just looks too cool!:D
Gofastoldguy 09-08-2011 10:54 PM
Slither...I have a FFR, 302 w/TWM and would like to meet you sometime at your convience. I live in Avondale. Give me an email at bbryan00@cox.net or call 935-0865. Thx
Bill Bryan
Gofastoldguy 09-08-2011 11:17 PM
Air Filters for TWM
Originally Posted by Crazylunker (Post 1150262)
I'm actually not having any problems with the tune, I'm kind of old school and like the simplicity of the carb and distributor, What is putting me over the edge is finding an air filter/screens I like that doesn't cost an arm and a leg. I'm running an electromotive tec3 distributorless, I like the period correct look of having the distributor and wires as well.
Try to contact Bill Hirsch in Warren, Michigan @ Bills B Racing. Email is Stackcovers@aol.com, Tele: 586-883-0942. He's a great guy and offers a good filtered product that reduces HP at intake the least of all filters I believe. He can explain it better than me. I noticed a difference in my TWM immediately.
Regards,
Bill Bryan
GordsFord 04-04-2012 12:43 PM
Quote from twobjshelbys
"One thing the fuel injection does though is put a pretty hard limit on the top RPM. Mine is 6500, but the engine ought to be capable of doing something like 8000 with a good carb setup. My engine is a Roush 427IR Windsor based."
Why do you say that the fuel injection puts a pretty hard limit on the top RPM at 6500? I am planning to put the 8 Stack Injection (Classic) units on a 427 Windsor solid roller cam engine that I expect will easily rev to the 7500 rpm + range. Does anyone have comments on this?
Thanks,
Gord
Slither 04-04-2012 02:28 PM
Thanks,
Gord
I have NEVER been limited to RPM's in the 8 years I have been running the TWM stack injection and the Redline ECU! Why would the injection system put a limit on RPM? Wouldn't that fall under the ECU's performance? My engine is a Dave Dralle built all aluminum big block FE. Could there be a difference there maybe?
GordsFord 04-05-2012 11:13 AM
Slither
I agree that there should not be any limitation of RPM by the 8 stack injection itself. That is governed by the type of lifters, valvetrain and ECU. With a solid roller cam, good valve train andfuel system and the correct ECU programmingThe power level at high RPM and is then dependent on the cyl heads, intake and throttle body flow rates. RPM achieved is governed by the mechanical components.
I suspect that the 6500RPM that twobjshelbys refers to is mainly governed by the ECU and hydraulic roller lifter valvetrain.
Gord
Slither 04-05-2012 11:32 AM
Originally Posted by GordsFord (Post 1184329)
Slither
Gord
Makes sense to me. I agree with you!
*13* 04-05-2012 12:27 PM
Originally Posted by zrayr (Post 1150348)
uhhhhh, the OP's already stated that he likes the look & feel of original type equipment. Nothing wrong with that. That's the basic reason we ALL like Cobras.
Z.
I couldn't agree more. Nothing wrong with a polished arruminum cobra with stack injection, if that's what gets ya goin'. Some of us just like it old school.:MECOOL:
andig 04-05-2012 01:05 PM
1 Attachment(s)
Agreed, I just love the look!
Andig
Cashburn 04-05-2012 05:57 PM
Andig
New tune today... Seems to be running mucho goodo. :D
mdross1 04-07-2012 04:47 AM
I too toyed with the idea of how to leak fuel into my build but then it was either Webers or a single carb.Ran an 850 dbl pmp for a few years never liked the rich idle loved everything else.Then discovered Dan Davinci he built me a 1000cfm dbl pmp all I can say is Wow, both me and the 460 could not be more satisfied and the idle is just what I had hoped for lean and nasty! EFI of any kind was never considered partly because of the expense and complicated nature of the beast,not to mention no narly idle with electronics.Finally for me wanted the old school look when hood was lifted,it speaks volumes to we old schoolers.
xlr8tr 04-24-2012 10:31 AM
I love everything about the stack setup... except the COST... cant justify it yet. Clsoe to $10,000 recently quoted for a full Eight Stack system including computer and fule pump etc.
8 Stack Fuel Injection/FAST XFI Computer
429-460 cu inch Ford with 2" velocity stacks included $7595.00
Aeromotive Fuel Pump, regulator and fuel lines - AN/Steel braided high pressure : $1199.00
Polished Intake Manifold: add $599.00
Polished Throttle Bodies and Stacks : add $1099.00
100 Micron Screen Stack Covers: add $399.00
Maybe when it fails aircare emissions testing next week I can justify it :)
trularin 04-24-2012 10:42 AM
My weber works great.
I can cook burgers, dogs, brats and chicken all at the samne time. That charcoal taste meake the cookout.
That is my weber.
:D :D :D
littlewave 04-24-2012 01:23 PM
Andig
That is just beautiful!! Carb....aaahhh no thanks!!:3DSMILE:
