Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Like Tree3Likes
  • 1 Post By twobjshelbys
  • 1 Post By cobrarkc
Old 03-06-2024, 12:56 AM
Default Cobra
My name is Ruslan.
I'm new to this forum.
I recently bought a Cobra.
I started preparing the car for the summer, but I have problems with the ignition.
Can anyone help me sort out the ignition? I want to change the entire distributor with wires. Сan anyone help me tell me exactly what engine I have and where I can buy good parts.
End my Cobra foto, end engine foto too
Old 03-06-2024, 01:00 AM
Мaybe someone knows the history of this car
Old 03-06-2024, 04:36 AM
mrmustang's Avatar
Gold Star Contributor
Welcome to the madness.
I can tell you that the cobra replica you have was made by Contemporary, but without some casting numbers from the block and heads, won't be able to tell you the basic engine specifications. Google "Ford engine casting number locations" and get back to us with what you find on your car.
Or, see if there is a part number on your distributor and google that to see what it fits, then order it's replacement accordingly.
Bill S.
Old 03-06-2024, 05:36 AM
Default Cobra.
Senks for fast answer.
I'll try to find the part numbers for the engine and cylinder heads.
How can you determine what year of manufacture this car is?
I have very little information about this car.
Мaybe there are ways to find the history of this car?
Best Regards
Ruslans Kurecs
Old 03-07-2024, 04:53 AM
Default Cobra
Does anyone know the history of this car?
Old 03-07-2024, 09:52 AM
mrmustang's Avatar
Aftermarket sticker, does not have anything to do with your car.
What is the VIN? Is there a real manufacturer plate from Contemporary Motorcars on the car (usually somewhere in the engine compartment) Does it start with CCX? If so, the VIN as a whole may be able to be used to whittle down a rough date of manufacturer from other known Contemporary Cobra replicas.
History might be a bit harder, where was the car purchased out of? Is it in the US, or overseas? Let's start with the VIN, regardless of what it is, and perhaps we as a group can further assist you.
Bill S.
Old 03-07-2024, 09:54 AM
twobjshelbys's Avatar
There are two threads active on this. It is almost never a good idea to post twice
cycleguy55 likes this.
CSX4005LA
Old 03-07-2024, 02:34 PM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Based on the picture of the engine it is definitely an FE motor with an MSD distributor
Cobrarich
Old 03-08-2024, 05:03 AM
Cobra Make, Engine: Contemporary Classic Cobra CCX-3-3967
Based on the tag you showed on your other post CCX-3-3940 is most likely from 1995/1996 at contemporary but date on when the car was finished and title is unknown to me. My CCX-3-3967 is from 1996. Engine is FE family(390,427,428) not 429/460 series. I don't see your coil in the photo. Do you have an MSD 6AL control box?
https://www.summitracing.com/search?...20distributors
One resource for casting numbers can be found here.
https://www.erareplicas.com/427man/engine/partnums.htm
cylinder heads casting numbers should be found between the center 2 spark plugs.
Old 03-08-2024, 05:22 AM
cobrarkc's Avatar
I just noticed this, it looks like your distributor cap is not on correctly. The hooks that hold it down to the distributor are misaligned which will throw you timing off.
Morris likes this.
Cobrarich
Old 03-08-2024, 08:53 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Definitely a Ford FE engine. Could be 390, 428 or 427. They all use the same distributor. Go to Summit Racing online and you will find several choices for the Ford FE.
I am not sure the cap is on wrong. The MSD has an option to remove the clips and use screws for the hold down. That is what that looks like.
Old 03-08-2024, 05:47 PM
The tag above is a 1969/70 Shelby Mustang door tag.
Old 03-18-2024, 11:40 AM
Cobra Make, Engine: Shell Valley, 410 SBC, AFR, Lunatti, Edelbrock EFI, (old) (new) FFR Daytona Gen3, White w/ Blue, 408, Sniper, AODE, Power Windows, Power Locks, AC, Power Steering
After you fix the ignition, throw away the air cleaner. It is much too small. It is a serious restriction and will cause many issues. Find something big (14") that fits.
