-   429/460 Engine Talk (http://www.clubcobra.com/forums/429-460-engine-talk/)
-   -   Timing (http://www.clubcobra.com/forums/429-460-engine-talk/18605-timing.html)
bran3b 07-12-2002 08:17 AM
Timing
What should the initial timing be for my 460? The engine is relatively mild (9.5:1 compression, 750 cfm carb, cast heads...). I have an MSD 6AL controller and MSD distributor.
I am trying to diagnose a stumble when the secondaries open, but want to make sure that everything else is correct before I start chasing that symptom.
Thanks,
Bran
HighPlainsDrifter 07-12-2002 01:42 PM
Hey Bran,
I have a mild 9:0 to 1 pistons,460 with 280 comp cam. I run a msd 6al and accel distributor with 12 degrees of vacuum advance. The vacuum at idle will get rid of the stumble. I set my initial timing at 14 degrees and mechanical springs at 24 degrees, so 38 degrees total timing and another 12 of vacuum at light throttle/cruise which drops off under W.O.T. I have no problems with pinging running 92 super chevron.
Perry.:cool:
