-   429/460 Engine Talk (http://www.clubcobra.com/forums/429-460-engine-talk/)
-   -   harmonic balancer ?? (http://www.clubcobra.com/forums/429-460-engine-talk/37483-harmonic-balancer.html)
zman 12-31-2002 03:08 PM
Hi,
Will a balancer off of a 460 cu in fit on a 429 cu in???
thanks....:D
A Snake 12-31-2002 03:41 PM
Physically yes, balance weight no.
Al
SFfiredog 01-01-2003 10:08 AM
The balancers will interchange. All 429s are internally ballanced. All early 460s are internally ballanced. In the late '70s Ford lightened up the crankshaft and blocks on the 460s. They externally balanced the engine with a counter-weighted crankshaft spacer. As long as you use the proper crank spacer with the proper crankshaft, you shouldn't have any problems.
--Mike
