Need to notch the frame need advise
I have a LA Exotics and we are in the process of dropping a 466 Ford crate motor into it. We need to notch the frame next to the starter to make it fit. I have been told it should be reinforced but I am unclear on exactly the best way. If you have any advise or photos please help. Thanks a million once again!!!!
| Tim Brewer |
06-05-2004 08:08 AM |
I have basically the same engine as you, but it fit great between my lonestar frame rails. My problem was with the shifter on my toploader. I had to notch out a 3" section of the corner of the seat pan. After that, I welded 1/4" steel to fill in the hole I had cut out. No problem. I also had to cut the side of the bellhousing by the starter.
Good luck, Tim
| jdean |
06-13-2004 07:28 PM |
DanP,
If you are having to notch it because of the starter, you might look to see if a smaller starter is a solution.
Just a thought.
John
| Jim Werth |
06-14-2004 04:59 AM |
Give B+B a call. I'm sure they can help you. Jim
Spoke to B+B Cobras and they gave me great advise and a drawing on how to modify the frame!! My cobra is at a really good body shop that will perform the work. Thanks again to B+B for their time!!!!!
| All times are GMT -7. The time now is 12:19 PM. |
