Tremec 3650 transmission??
Hello,
Stupid question but will a Tremec 3650 fit on a FE 390 with about 450hp? Or what transmission would be best for that motor? Does anyone have a transmission that they would like to sell in the Atlanta area (or ship to)? Thanks for the info again, Josh |
Found this info. Might be helpful. If the Mustang guys use the trans with all their power adder I can see why you couldn't use it with your 390.
TR-3650 used in 2001-present Ford Mustang GT's 1st: 3.380 :1 2nd: 2.000 :1 3rd: 1.320 :1 4th: 1.000 :1 5th: 0.620 :1 Rev: 3.380 :1 Note that in the other TR-3650 applications, the gear ratios are the same with the exception of 5th gear. Recommended Oil and Fill Capacity TREMEC engineers have recommended Texaco-Havoline Dexron III/Mercon Non-Synthetic ATF. The most recent Ford owner's manuals specify 3.17 quarts of a non-synthetic Mercon ATF. There has been a significant amount of confusion regarding the proper capacity and proper type of ATF for the TR-3650 which may have a correlation with a rather large number of complaints about notchy shifting, shift "nibbling", noisy synchros, and grinding gears. I don't like the gear ratios. First is two low and the over drive is to high. What rear gear ratio are you using? Most Mustang GT have a 2.79. What RPM range does your engine make its power in? |
| All times are GMT -7. The time now is 04:06 PM. |
