514 operating temp.
http://www.clubcobra.com/forums/429-460-engine-talk/91133-514-operating-temp.html)
| panteraman |
09-09-2008 07:31 AM |
514 operating temp.
Hi fellas, I have an svo514 in my car and it usually runs around 190deg. When I pull a mountain run or hit heavier traffic on the fwy the temp climbs to about 205deg (at least according to my guage). When I park though i get some puking out of the overflow. what is the upper temp operating range of this engine? Anyone.... thanks!
| Tim Brewer |
09-09-2008 08:04 AM |
205 is really no big deal.. sounds like you need a higher pressure cap and maybe a beter overflow system. My engine has seen 225 degrees many times with no problems.
| 392cobra |
09-09-2008 08:13 AM |
I don't think you have a temp problem.
You may be overfilling the tank/rad.
| scootter |
09-09-2008 10:50 AM |
Do you have an expansion tank? If so, that should only be about half full. I was in dead stop traffic the other day for about a half hour with the temps outside around 95 or higher, and mine never went over 100 deg cel.
Scott
| panteraman |
09-09-2008 11:00 PM |
thanks y'all....I do have an expansion tank and I keep it about 1/2 full. I'm thinkin that because my 180 deg header is about 1/8th in. away from the bottle that i might just be boiling it right there. guess I'll try a heat wrap on it an see what happens.....thanks for all your tips!!
ps...nice avatar 392...my eyes will be bouncing for awhile...
| All times are GMT -7. The time now is 04:43 PM. |
