| kevken59 |
12-31-2008 09:24 AM |
Please read my reply to the last post- low oil pressure
Hi. I just tried to send a new post as a reply to a prior post. I need help!! I have a 429CJ with what may be a bad bypass valve in the block causing low/no oil pressure. Is there such a valve in the block, where is it, and how can I check/replace it? Thanks!! Kevin.:confused:
| bobcowan |
12-31-2008 09:49 AM |
There's a pressure relief spring in the oil pump, but nothing in the block.
| mpanten |
12-31-2008 09:58 AM |
This may be a dumb question but have you checked the gauges? If you are running smiths gauges they fail quite frequently
| All times are GMT -7. The time now is 04:33 PM. |
