Old 01-13-2004, 10:41 AM
JL1924 JL1924 is offline
Cobra Make, Engine: Shell Valley Cobra. Engine is a Ford Racing 302 Crate motor, with Tremec 3550 5 speed trans.
Default Tremec 3550 shifter locations
Pete,
Just browsing these forums, and ran across Mike Forte's answer to your shifter location problem. If you look at the following site:
http://www.gearheadracing.com/Refere...FordTremec.htm
I think you will see that Mike is probably referring to the measurement "A" which is the shifter location as measured from the front face of the transmission. 12.5 and 16.75 make more sense then since the stock location is 19.5. Probably worth talking to him about it to make sure, but if measured from the face, then it would probably do what you were looking for.
JL1924
