Old 02-07-2004, 10:21 PM
Barnsnake's Avatar
Barnsnake Barnsnake is offline
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
My favorite method is to use two screw-type stainless hose clamps about 1/8 inch apart. Cut between them with a cutoff wheel and the braid on both sides is under control. When you get ready to put the collar on, loosen the clamp a bit and it will slide back down the hose as you thread the "collar" onto the hose. After the fitting is installed. loosen the clamp until it will slide over the fitting (or loosen it all the way apart if needed).
Jim
A Gnat! Quick, get a sledgehammer!
