Old 02-21-2004, 03:04 PM
Unique580hp's Avatar
Unique580hp Unique580hp is offline
Cobra Make, Engine: Unique Motorcars 427 Cobra. 427 Side Oiler. Dual Quads.
Wink Let's hope the car is better than the spelling!
I just looked at the ad and was amazed at how many words were misspelled. I hope that if this is the same person that assembled the car that they can read the directions better than they can spell.
Here's the ad:Look for things like (Carburator, Defferential, Cony)
If you are looking for an ERA Cobra this is the one for you.
1992 ERA 427S/C, ERA155.
10050 miles, with Ford 427 Side Oiler motor.
Bored to 454ci stroker.
Motor (Carburator Clutch) has been overhauled at 8000 miles.
Defferential Gear has been changed to 3.31.
Suspension has been overhauled.
Front Cony coil over Special D.
Rear Cony.
Front Brake inch up, brake hoses all new mesh stainless.
Larger size Brake and Clutch master cylinders.
Front and Rear Brake pressure control switch.
Larger size Radiator with sub radiator.
Custom motor room shroud, electrif fan, 120A Dinamo.
New plug wires with MSD, added oil cooler for increased capacity, oil filter moved and kit changed.
Oil puke tank installed.
Replaced head lamp (lucas 3p high wattage).
Replaced head lamp rings.
Sumith untaime Clock wise 7 meater KIT.
16" steering wheel.
ORG backward shifter.
Left and Right Seat replaced, driver side 4 point seat belt, and roll bar with crossmember.
Halibrand ORG wheel.
Stainless "Torrance california" Logo spinner.
Good Year Eagle DRY tire 90% good.
Replaced side mufflers.
ORG Hood lath opener.
Talbot Green Stamp Rear View Mirror.
Replaced wiper arms.
Changed side Bent loober to Aluminum.
Replaced ,Jack Pad bumper (have original over rider style bumper)
Soft Top have side curtain and tonou cover.
All record for 11 years kept.
Asking US$60,000.00 F.O.B. Torrance, CA.
Don't miss this deal!!
1st car was a Cobra, hopefully my last will be also!
