Old 04-12-2004, 08:00 AM
mickmate's Avatar
mickmate mickmate is offline
Ant, does the Almac have some frame issues or are you going for different look or application on the hardware? You can make about any hardware work if you are able to move suspension points around to where you want them. The trouble is where do you want them. The Mustang II set up is popular as all the geometry stuff is a known factor. This obviously wasn't designed for a Cobra which is why I wouldn't put this set up in my car. There's a lot to be said for someone having it all figured out for you though so the hard part is just putting it in there. It comes down to what you want, can afford, and can do yourself. What is your other hardware, spindles etc?
mickmate
http://www.actoncustom.com/
