  #23 (permalink)
Old 11-18-2004, 06:16 PM
Lubrecon Lubrecon is offline
Send a message via AIM to Lubrecon
Thanks both of you. My cam specs are Int 234, exh 244, lobe sep 112, lift 520/540. However, I don't know how much overlap I have. How can determine OL as it is defined? Aggie, I am going with your set up as a starting point. I will not be racing it so I think the 37's will be ok also.
What are all of your thoughts on linkage. I am inclined to make my own, with a lot of help from my friend with the GT 350. He made his own and it is very trick. He can adjust each carb individually with the heim joint linkage to each carb. What are the feelings on the linkages from Inglese and others on the market?
Thanks again for all of the help, I will be needing more I am sure.
Jerry
