Old 12-28-2004, 10:10 AM
davidlee davidlee is offline
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
Sledge,
At least for now I'm gonna keep them.
Squirrel.
To adjust your rear ride height you have put the rear of the car on jack stands and put a jack under the rear a arm at the area of the shock, remove the lower shock bolt and then lower the a arm to take the pressure off of the spring. Then you are able to adjust the spanner nut on the spring.
I tried first to adjust the height on mine by just removing the rear wheels and using the adjusting spanner nut but there was too much pressure. All I got was skinned knuckles
David
