Old 04-10-2005, 06:24 PM
Alex Evonosky Alex Evonosky is offline
Cobra Make, Engine: Building from scratch
Default Pictures in my Gallery
Bob,
Sorry for the late reply.
I have posted a few pictures in my gallery
Yes, you are correct, there are many produts to choose from as far as control arms.
I am no engineer and also sure there are lots of builders on here that are smarter than me.
As for the front control arms, I went with the Pole Position upper and lowers.
Part numbers are as follows:
Lower Left: 9300
Lower Right 9301
I will say that for my needs I did remove the shaft and machined some bushings so I could moune each side independently.
As for the uppers they are 9200RTF Pieces.
I ordered the 9200RTF but found that the welded threaded, shaft was at the wrong angle for my needs So I had Pole Position send me the parts and I will weld them to my needs.
Also, I used the 9200-27 adjusting sleeves for the front and 9200-23 for the back side. there again, I had to cut 1" off as they do not sell 7" sleeves.
As you can see, my project is nowhere near stock or simple.
I am sure there are others on this site that are building from scratch with more conventional parts which may be of more help.
I am also using himes instead if tie rod ends.
As for the rear, I am going to use the CWI quick change and will fabricate the needed brackets at that time.
Cobracer
Cobracer#15
