Old 05-19-2005, 07:35 AM
Three Peaks Three Peaks is offline
Grumpy,
Ah-ha, there you are. I was thinking you gave up on me. I wasn't aware you needed more information or I would have certainly forwarded it to you.
I cut one of the motor mount pedestals yesterday to mount the top plate and did some measuring and realized this is going to make my oil pan hang approximately 3/4" below the frame rails using your measurments. Is this what you had in mind?
The suspension mounts are per the CR drawings (upper and lower) and all are drilled. Will you be able to design the suspension pieces around these points (they are drilled- 1 1/2" one side, 5/8" the other on each point) or am I going to need to relocate them for the suspension pieces? I can easily reconfigure the 1 1/2" holes as per our discussion to accomodate your adjustable arms.
The steering mounts are per CR also, and I had decided to use the ATSCO 6804 rack or the FR Cobra rack as per our discussion.
Is there any other information I can furnish to help you with your end?
Hope to hear from you soon- Thanks, Bob
