Old 06-10-2005, 03:39 PM
sexzsn8k I got a set from cobra restorer. The problem is ground clearance. They are fiberglass. They just scoop the air up on the rotors and pads. They make them for the fronts and rears. You could get a set from ERA that they use on the FIA car. You would have to modified them to work. You could also close off your foot box air ducts and take the duct hose to the back of the brakesNascar has orange hose that will take the higher heat. You can buy these little fans that fit in the hoses and push the air on the rotors. I don't have a digital camera. If you donot mind a periscope, Don D has a great brake cooler system for the rears. The captain's hat is extra Rick Lake
