Old 04-18-2006, 07:40 AM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
I installed a Tilton hydraulic throw out bearing and I have not had any difficulties at all. I followed the instructions for the initial setup, installed it and basically never touched it since. I am running a 351W, toploader, and a Ford Motorsport clutch and flywheel all inside a Lakewood bellhousing. Routing the hydraulic lines is a bit of a pain when installing the tranny, but other than that it is a great setup.
One thing I did was to run a permanent bleeder line so that I could bleed the system with everything in place, if necessary.
Wayne
Don't get caught dead, sitting on your seat belt.
