Old 06-12-2006, 03:36 PM
Leeroy's Avatar
Leeroy Leeroy is offline
I too went with Ians setup. Not sure what the cost is but I would think it would quite a job to come up with your own. I still had to heat & bend the brake/clutch pedals over towards the tunnel about 25mm to be more comfy. I used a Ford EA accel. pedal which mounted quite easily but also had to bend the arm to suit a good position. I used the EA cable also, had to reduce its length and fitted new s/steel wire inside and made up the lug at the T/body end. My complaint would be that the pedal travel is a bit too long.
Leeroy
