Old 07-26-2006, 05:34 PM
venom0427's Avatar
venom0427 venom0427 is offline
try theses two, the brighter one, is the one out of a mustang (plain) and the other is out of a XJ6 V12 turned into a quad cammer, the work i saw done a few years back was done by a bloke in Caulfield, he would take a std V12 jag engine, buy 2, 4.1 Cyl heads, cut one of the up to enable It to go on the other side, then you make 4 cams to suit, timing chain, inlet and you use 2 ECU’s out of a vl commodore.
It will make around 450-500HP.
I’ve seen one in Dandenong were he was going to put it into a 32 ford tourer, with a custom supercharger. Not bad. Tried it with a sdt jag in a cobra, but the engine was to long, then tried to build an XJ13 using the same engine, but alas it dint come to fruition.
But see that Bedford has done one. O well
[IMG][/IMG][/IMG]
