Old 10-16-2006, 06:54 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
I am not sure this will be of any help at all as I have no light, just a dash mounted volt meter which reads my battery and shows what voltage the alternator is putting to it. Do you have a volt meter, and if so, does it work correctly, IE shows 13/15 volts when running and nothing once the engine is shut off? If everything else is working ok, it would almost sound as if you just have the light wired wrong. It is showing charge when the engine is running and should only light when you lose the charging, such as when you shut the engine off. I am not familiar with your wiring set up, so will have to leave that to the people who are. Sorry I can't be of more help.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
