Old 10-24-2006, 12:01 AM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally Posted by Excaliber
...Some of us WANT the 'real thing'...
If you had been paying attention you would have noted that Archrms's question was "...is there any reason other than "authenticity" that makes an original block any better than a new Genesis?"...
If you want "the real thing", great. Buy one. Some of us on the other hand, have tried the "real thing" and, while deeply greatful that Ford brought out this wonderful engine, are tickled pink that better versions are available.
...make no mistake, if you don't build it right you can blow up ANY block!
As though a cylinder wall breaking has anything to do with how it was built rather than core shift causing thin cylinder walls. It's virtually impossible (never use that word!) for a Genesis block to have this problem unless taken out to the max, which is .135 over the stock 427 bore...and you can always sleeve it back to 4.250 and start all over again!
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
