Old 11-23-2006, 08:00 PM
Dwight's Avatar
Dwight Dwight is offline
Default 130 in 3 rd
jarendall, what is your rear gear ratio and what trannie do you have? I have a TKO 600 and 3:55 rear end with 25 1/4" tires. 3 rd tops out at 103 & 4th about 132 mph.
Ted G, If this is your first hi-performance raw in your face car, start with 300 -350 flywheel HP and after a year or so go for more. A mild 351w will give you 300 + and you can stroke it to 408 later ( about 430 rwhp ). If you plan your car with the right trannie, tires and rear end gear ratio you can do with a lot less HP.
Dwight
