Old 12-12-2006, 09:20 AM
Jimi G's Avatar
Jimi G Jimi G is offline
Alright guys here is the official answer on the alignment of the third gears, this is the answer I personally received from Tremec. The reason the third gear on the cluster is over a little bit is to allow for the machine that cuts the teeth into the gears. The original 3550's had a two piece cluster which allowed the gears to butt up to one another, but since it was a weaker design than the new one piece cluster they changed it. He also informed me that even though the gear is shifted a bit it did not compromise the contact surfaces between the upper and lower gears. I tried to load a picture of the two shafts but it was to large so I put it into my photos for all to see. I hope this clears things up a little.jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
