Old 07-13-2001, 12:35 PM
JOHNNYCOBRA's Avatar
JOHNNYCOBRA JOHNNYCOBRA is offline
Cobra Make, Engine: 1984 S-V WITH A 5Liter Eight stack EFI
Thumbs up Hello gents
Just checking in to the discussion. I own an older Shell Valley. and started the rebuild process, updated suspension, engine etc.. I too wnt thru some hassels with the body but finally got it worked out. I re-fiberglassed the mounting holes in the body and re-drilled them, this let the jbody sit level on the frame. also had to re-drill the bolt hole locations in frame. it all seems to be centered and leveled now! I'm having a little trouble with the door hinges not wanting to re-install to the same locations they came off of, Probably because the body placement changes??
