Old 04-26-2007, 03:22 AM
cobbindale's Avatar
cobbindale cobbindale is offline
Cobra Make, Engine: Classic Revival.
Heard back from Pedders today, the same bar as Phil is $225ish with saddles and bushes. This bar is 615mm between lower arm mounting points and can use a cut down link like the 4208 jobbie from Pedders with the balls at 180 degrees to each other and 500mm across were the saddles mount.
The stighly different bar than Phils is $242 which comes with saddles and bushes and 3 adjustment positions. This bar is 100mm wider which should sit even with the mounting holes in the lower arms and use the 4204 link and is 400mm across were the saddles sit, (noticed I said should).
I'm happy to buy the wider bar and take some pics if you like. Discounts on multiple orders were breifly discussed and only a few bucks mentioned as a saving. He estimated $15 - $20 for shipping to Sydney.
If you wish to have a chat to the guy, his name is Scott at Pedders Geelong Ph. 03 52213233.
Cheers.
