Old 06-21-2007, 07:03 AM
dandascott dandascott is offline
Thanks for the input. I am far from an expert on fuel plumbing. The logic was that the electric pump would keep the mechanical pump supplied with a more than ample fuel supply, the mechanical pump would only need to distribute the flow at a hopefully even pressure.
I am sure what you have described will work fine, what I have is probably overkill.
Thanks,
