Thread: Seat Question
Old 08-16-2007, 08:06 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Dennis Olthoff fabricated some aluminum bar stock into a couple of spacers that go under the front seat adjusters for a few of us. They effectively raise the front of the seat - naturally forcing the seat back to tilt back further. To use them, however, we needed to use longer bolts in front to mount the seat, but they're easily found and easy to replace.
You could probably accomplish the same effect with longer front seat mounting bolts and a stack of fender washers. Just be sure and loosen the back seat mounting bolts as well...then once the washers and front mounting bolts are in place, retighten the rear mounting bolts. Using the washers you could experiement with how far the lean angle needed to be for you to be comfortable.
I found I didn't like the angle of the seat bottom...felt like I was reaching uphill for the pedals...just my opinion, though. You may find you like it fine.
Hope this helps...good luck.
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
