Old 09-03-2007, 12:22 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Here you can see Sandwich putting the straight edge of some calipers across the washer. You can see it is severely bent! The steel of the washer indicates is is probably mild steel and so it has no spring to resist permanent deformation from the pounding of the rear suspension. As the suspension beat on the washer over time, it has yielded letting all the preload out of the suspension--major bummer waiting to happen in the driver's seat.
