Old 10-05-2007, 11:12 PM
1966plus's Avatar
1966plus 1966plus is offline
Hi,
yep I believe it was a 390 block. The build up spec did vary a little from the initial one supplied from Huddart's, you are quite right, it is a Performer manifold, the volume I have been informed is 454ci . To build up with a 427so over here would probably add another $2000 or so The carb going on is a new Holley 750cfm 4150hp unit.
The baldy units shouldn't have a problem as the covers currently on there are quite low profile as well, but if there is a problem there are spacer kits available to give me the room I need.
This is the header system that will be going onto it (bear in mind it is a GT40 one so goes up rather than down ) The photo was taken with the system mocked up on an old engine just the photo over in the US.
2" primaries, crossover (where applicable) and then 3" back from the collectors
Craig
www.miragemk2.com
