Old 05-09-2008, 08:54 AM
patrickt patrickt is offline
Originally Posted by CJ428CJ View Post
Get some of that dye that you add to the oil. It's amazing how an oil leak in one place can barely creep a long a seam or something and look like it's coming from somewhere else.
100% Correct. I had a leak that appeared to be coming from the transmission (and a leak that was dripping from the frame) that I simply could not find the source. As soon as I used the dye to the engine oil I was able to trace it to my IM/Head/VC area and take care of it. Before you assume it is transmission oil, use the simple dye test first to make sure.
