I would recommend picking up or borrowing a device I've used in the past. Basically, it is a cheap doctors stethascope (sp) with the listen end taken off and a hollow , thin copper rod braze or slipped into the single tube line in it's place , about 2 feet long, The idea is to place it on the block, near suspected areas to listen for source of noise. Bearing or wrist pin issues are easy to hear as you rev the engine. Can also be done with an old fashioned 2 plus foot long screwdriver with a wooded handle...tip on block, ear on handle.
Reason: fat finger typing
