Old 11-02-2008, 12:56 PM
FWB's Avatar
FWB FWB is offline
is anything done to the motor, meaning if its just a mild built windsor a 750 dp
will be too much carb. whats the timing set at? if you can get away with a couple of degrees advance more bump it and see if that affects the flat spot
if it does that might indicate too much carb if the flat spot move up in rpms
when it occurs.
