Old 11-09-2008, 09:01 AM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Doug,
I found this FAQ on the McLeod site. It sounds like you cycle back and forth between the master cylinder and the bearing.
"Bleeding should be done first at the master cylinder and then the bearing, then the master and then the bearing again."
http://www.mcleodind.com/faq.html
The pressure bleeder is probably the best be to drive all of the air out of the system.
Doug
