You might get the body back in line with the cargo straps... in another fifteen years. I'm with DV. Probably that way to begin with. Does the body not fit on the frame or is this just a visual thing? 1/2" should be easy to tweak out but you need to hang doors and latches, trunk, hood, rollbar, quickjacks, and windscreen so they all play nice together then you can shim and adjust to see what cause it has on any of the peripherals. If it's just a visual thing, IMHO you'll never see it. Especially on a no-stripe car but even then, stripes might help mask the offset.
