Old 05-23-2009, 06:53 AM
mjmacqua mjmacqua is offline
Cobra Make, Engine: Midstates, 501
Default BG Fuel Pump Losing pressure/prime????
Guys looking for a little help.
Here is the issue. and all the details and recent changes.
I have a Barry Grant Fuel Pump. Pick up is a sump at the back of the tank. Pump is located in front of the tank.
I recently moved the pump higher to fit the filter to it directly as recommended by Barry Grant. Before this no issues. I have also changed all of the steel braided lines and reconnected or re routed (nothing dramatic here). I also checked for leaks and there appears to be none.
Now the issue. I put 5 gallons in a completely empty tank got the fuel pressure up at the carb, let it warm up and then went for a run up and down my street. On the way back I lost fuel pressure and coasted into the driveway. I tried to restart, but no fuel pressure at the carb. I tried cracking the fitting just before the pump with both pump on and off (hoping it was an air bubble), no luck.
Questions:
Do you think the pump went bad?
Is it possible the 4or so inches I moved it up is too high and it lost fuel from
the pick up with only 4-5 gal in the tank and then wouldnt reprime?
I am probably going to remove the fuel filter lower the pump back down and see if that works, if so, I will relocated the filter again.
Any other suggestions or help would be greatly apprciated.
Mike
