Old 07-18-2009, 06:22 AM
69boss429 69boss429 is offline
Originally Posted by scottj View Post
My motors always ran best without any advance so I've always lock out my distributors, but my cams have always had 260+ degrees at .050". On my 11:1 motors I didn't need the MSD start retard box as they always started without issue, but it was required (-20deg) on my high compression motors or they would blow teeth off the starter ring gear. A dyno is needed to determine optimal timing.
Scott
Question,
When you set the timing with your locked dist where do you set the mark?
With a digital timing light do you set total at TDC (say 32 deg or whatever your max is) mark or BTDC
